mikeswillys
I have a 2014 wrangler with 84k miles today I unzipped the back window rolled it up and took it for a ride. After getting on the highway going 60mph I started smelling a burning smell sort of like rubber. 600 miles ago I had the transmission filter replaced and flushed and also the rear differential and transfer case drained and replaced. 5 miles into the ride I decided to pull over and investigate. I crawled up under and started smelling around and couldn’t find anything. I checked the fluid in my transmission and transfer case and both are full. Opened the hood and had my wife hold the engine at 2500rpm and sniffed everywhere to see if I could locate the issue with no luck. I thought maybe an idler pulley had seized and was causing the serpentine belt to smell. Finding nothing I decided to keep going. I drove 50 miles smelling it occasionally. Stopped at a rest stop crawled under it again felt the rotors to see if they were hot and again could find no issue or smell it while it was stopped. I closed my rear window and haven’t smelled it since. So here I am seeing if I can bounce this info around and possibly see if anyone has experienced this and what it could possibly be.
