JPNinPA
Active member
No the fluctuating gauge isn't normal. I thought I commented earlier. It should be steady from idle up to rev limiter. A quick rev might make it dip and spike a little but it should be a smooth settle not erratic.
The electrical connection you mentioned above on the regulator is why I asked if yours is the same as the pic.
Regards,
JPNinPA
Sent using TapTalk
Regards,
JPNinPA
Sent using TapTalk
