luis New member Aug 20, 2011 #1 My jeep shakes when ever I turn the wheel at 50-55 mph but only then... What can be the problem steering isn't loose at all
Rob2336 New member Aug 21, 2011 #2 Try getting your tires rotated and balanced first it's the cheapest of all routes. Unless something is visually loose or bent.
luis New member Aug 21, 2011 #3 Rob2336 said: Try getting your tires rotated and balanced first it's the cheapest of all routes. Unless something is visually loose or bent. Click to expand... Well i got em balanced and said it was all good. Above 60 everything is normal. No ball joints r broken so it has me stumped
Bounty__Hunter Super Moderator Aug 21, 2011 #6 Sounds like a bent front axleshaft or bad axleshaft ujoint.
luis New member Aug 21, 2011 #7 I will check all those today. All the bushshing seems to be in good shape
luis New member Aug 21, 2011 #8 I wana add that the shaking is mostly at my steering wheel and is barley felt while sitting in the jeep
