Hi,
i own a 4.0 High Output jeep Cherokee, its was imported into th Uk from california a few years back. Anyway I have a bit of a problem and hoping someone can help, the car has been set up with an LPG fuel system, unfortunately someone has messed around with the electrics as with a lot of LPG conversions they diable the petrol pump to stop it running while the LPG is on.
So now it wont run on petrol as the pump has been disconnected. So basically what i want to do more for emergencies when I run low on LPG is wire the fuel pump onto its own independent electrical supply with an inline fuse and cut off switch. Does anyone know if its a 12v pump and is it continiously powered?
Any help and advice is much appreciated.
I've ahd the Jeep about 4 months now and can quite honestly say its brilliant, never let me down once, although I will need to replace the start motor shortly.
