Sine Deviance
I've got several new issues, looking for some input...
Okay... specs of the Joop are in my sig
First... I checked my dipstick the other day and noticed that there were some small bubbles in the oil. I just changed the oil about 500 miles ago, if that. It was cold when I checked it. This means there is water in the oil, right? If that is the case, do you think it is just condensation or do I have a real coolant leak? For reference it has been pretty cold outside here, in the 40s and 30s.
Second... When I crank up the Jeep in the morning I'm getting some smoke coming out of the tailpipe when I pull out of the driveway. The smoke seems to go away as soon as I am pulled out of the driveway, so basically about 20 seconds after I first crank it up. The smoke appears to be white in color, suggesting water. But since it only smokes right after being cranked up, would this suggest condensation in the fuel/exhaust? Or is a slight coolant leak into the cylinders more likely?
Third... My valves seem to be rattling under acceleration until the engine gets up to temp. It sounds like valve tick but it's really just a ticking sound. At 2000-3000 RPM it will probably tick a few times a second. Again, it's only noticeable when I'm accelerating or otherwise putting load on the engine. Is this just cold oil taking it's time to pump up to the valvetrain, or something else?
Fourth... I have noticed that the Jeep doesn't seem to be as "solid" as it used to be when I'm driving down the road. Nothing too noticeable, just a feeling I have. It seems like there are alot more rattles than there were when I first bought it and over the summer. I know that metal expands when warm. Now that winter is here, and there is no warmth outside to make the metal expand, would that cause rattling to be more noticeable?
Fifth... Once again, it's been pretty cold here lately. 40s, 30s, and this morning it was 22 F. However, the Jeep seems to be taking ages to warm up to temp. Town is about five miles away. I can drive all the way to town and the engine won't be fully up to temp yet. Isn't the coolant system supposed to have some kind of bypass that makes it warm up faster in the mornings? Or could this be some problem that needs fixing?
Thanks for any opinions
