Hi - my 1988 Wagoneer did not start. Replaced coil about 3 months ago, everything seemed fine. Then one day, turned over and over, no start. Took coil out, "pushed" metal contacts together on module for better contact with coil, put coil back in, started right up. That lasted about 2 weeks and did it again. Have now put in new ignition control module, started right up, second day did it again! Removed coil, "pushed or bent if you will" contacts on module and it started right up after putting coil back in. Anyone experience this? Please Help!!!???!!!
Thanks, Jack
Thanks, Jack
