No electronics changes. It's really a simple swap if you know the pitfalls to look out for. The injectors are 19lb (yellow) ford 4.6l. They just plug in. The main benefit is they have 4 holes in the end where the stock ones only have one hole. You get a much better atomization of the fuel mix. The hard part is getting the suckers to go into the fuel rail, I swapped the o-rings with the originals, someone on jeepforum said he put motor on them to help them slide in. Just make sure they're seat all the way. The throttle body is what had me pulling my hair out. Everyone says you have to reuse your oringinal sensors ( tps and iac) and you do. WHAT they don't tell you is you have to swap out the iac HOUSING on the tb. There is a gasket, be careful not to mess it up, I don't think you can buy just the housing gasket. Don't forget to buy the tb gasket though. Other than that, it's super simple. I also put on an Accel performance coil (easy, 2 bolts, 2 wires) If I haven't mentioned it before, remove the reducer in the front of the airbox. This is imeadiate free power upgrade:lol: Good luck, if you have any questions just ask.
