identifing dana axles
j salley
I have a 1992 jeep cherokee. Could yall explain to me how i can go out and look at my axles and tell what dana axles they are.
I believe the rear is dana 35 and the front is dana 30. Is this right. Im not sure.
Thanks.
I'd suggest using this form and request a "build sheet". This will give you a list of everything on your Jeep when it was built:
Contact Jeep
In the short term, you can look at the axle - if there is a plastic / rubber fill plug on your back axle then it's a Dana 35.
Dana 30:
Dana 35:
Dana 44:
Front will be a D30, rear could be a D35 or Chryco 8.25. If you have ABS good chance it's a D35.
heres some helpful pictures i have collected over the last year
