I need help!
pnwjeeper4lyf
I have a 97 jeep grand Cherokee zj and I would love to get a 4inch lift but I'm not sure what size tires I should get without it having to rub and not have it drive horrid.
Terry will try to tell you to get 14 inch tires, do not listen to him.
When you look at the kits each manufacturer will have a recommended tire size for each lift. If they don't call them and ask. Because honestly if you trim enough ( and use the proper axles and bumpstops) you could run 40"s...
