All of a sudden, I've been getting a terrible metal on metal noise when I release my clutch. So, I dropped the transmission and replaced the pilot bearing and release bearing. The clutch was fine because I had already replaced everything last summer. I put everything back together and, of course, it's worse. I'm getting the same sound now when I start to engage my clutch. Is my release bearing hitting the fingers on the cluch cover? Or is my release bearing hitting the clutch and causing that sound? Other questions...What is the position of the release bearing when the transmission is put back together...does it sit outside of the clutch housing, or is it sitting beyond the fingers near the clucth? When I bolt down the clutch housing does the clutch itself get sandwiched tight between the flywheel and the housing or should there be some movement?
I also replaced the slave cylinder. I have not checked the fluids in the transmission and transfer case but I don't think that is the problem. Everthing went fine last summer when I replaced the clutch...until last week! Help!?!?
