92yjw\\305
88 Cherokee
I am debating on which is the easiest and cheapest way to get more power and sound from my 4.0L. I am thinking about stroking and using the crank and rods from a 4.2L . Or my other option is to use high compression pistons with a cam on a stock 4.0L. Which of the two ideas would be chearest, easiest, and less of an aggravation? Also do you have to bore the cylinders when you stroke an engine. Think jeep is going to be my daily driver, its got 33's and a 6 inch lift if that helps any.
thanks
thanks
