greg92jeepxj
Official Supporter
Best of luck this Sunday , looking forward to positive reports . I'm certain all the labor entailed will be for the better.
Update: Changed out the exhaust manifold gasket. Actually there wasn't a gasket there at all. Just a gasket on the intake manifold. Pulled the old gasket off and put the 1 piece gasket I got from Autozone. Bolted everything up tight and also changed out the O2 sensor since I already had it there. Fired up the jeep this morning and there was a slight "bucking" but it doesn't seem to be as bad as it was before. I'm going to run it all week and report back at week's end of any changes
also, ran some Seafoam through the vacuum lines. No leaks were in the lines but boy did that thing smoke out the neighborhood...lol
Thank you for your update . It will also be interesting to note if the sea foam product is effective as claimed. I certainly hope it did a good job cleaning carbon from the jeeps combustion chamber especially around the intake/exhaust valves and hoping it cleans piston rings as well.
Since doing this disconnect your battery for 15 min to reset the PCM air fuel trim levels back to stock settings. They will be relearned. This may help as a richer or leaner mix may have been being called for due to any leak.
Hopefully your intake pins lined up and the gasket sealed any leak.
Found the below post on another forum because of someone having the same issues..... how plausible is this????
"Maybe you have a stuck thermostat?? If thats the case it may cause your fuel mixture to be to rich for a bit while the engine is still cold."
I'm not going to put any money on the stuck thermostat causing this glitch . I understand the point but a rich mixture shouldn't cause this . This jeep is fuel injected , not carburetored . Only bad injectors , bad spark or pcm or sensor glitch causes this kind of a miss. I believe you have already checked and cleaned all grounds including O2 and pcm ? O2 sensor swapped too. If wiring harness is trustworthy and not causing intermittant condition , it seems that another drive and scan will have to be performed paying attention to one sensor at a time to,rule in or out if any are operating out of range at any time. Process of illimination . Also curious if spark quality is consistant from idle through cruise to WOT. All kinds of things come to mind to check at this point but I know you have checked so many by now . Intermittant is the problem and that could be spark , fuel,pressure , sensor communication or even pcm . But I'm not ready to blame a pcm . Not so fast. The only way that stuck thermostat can even cause such a condition is if the CTS is faulty and causing erratic reading . Before swapping any more parts , the scan total has got to show values of sensors while driving . It seems to be a cold engine condition now ( open loop ) , so the problem is not present when warm ( closed loop ) ?
Simply: No
More: You have this issue when the engine is cold. So it doesn't matter what the thermo is doing.
In your first post , among the parts list you've changed you mentioned a CKS. Did you mean a crankshaft position sensor ( CPS) or a camshaft position sensor (CMP) ? Kind of confused , not familiar with that abbreviation. You can try to wiggle the harness of the crank shaft position sensor while the engine is idling to see if the engine stumbles or stalls . I did mean to ask if you changed or checked the cam shaft position sensor which does have an important role and can cause symptoms your having . I don't remember if a DTC popped up related but at this stage , yes , it should be checked . It can be checked with a volt meter by back probing the harness still connected . You should see 5 volts . But I think since this problem is intermittant you may not see this part showing irregular readings unless it actually does miss once and you'll see that better with the scan tool when driving. The bench test dosen't always yield results and causes you to chase your tail. That's why diagnostic shops like lab scopes $$. I,will however respect your thoughts and we shouldn't rule out anything but before you change any more parts ($$) , evidence is needed. But yes , a CMP is probable and should be properly checked. I still believe all sensors should be read but to find the one that misses at the crucial moment is tricky. For now , if at least the values can be checked to see if at least all sensors are in range , this is still helpful . But I know that you do not want to over look the problem by thinking you checked one and found it good but still intermittently causes the problem . Could be a ground issue with one or defect or poor quality. Getting the right parts seems to be getting tougher. I've read that even MOPAR O2 sensors take a back seat to NGK. Just makes it tougher , I know.
Yes , what is referred to as the camshaft positioned sensor is the sync signal generator , or stator which is found in the distributor. See if your repair manual has a test procedure for this sensor . My 1992 chrysler service manual has a general procedure to check for voltage of 5 volts but since we know the engine starts and runs this procedure will show 5 volts leading U.S. To believe it is good. The real test will have to be done with the engine running . A good scan tool may be able to perform this but a lab scope will . That's the tough part. I'm hoping your buddies scan tool can show live data in terms of signal reference from the camshaft position sensor. Hate to ask you to keep grubbing his scanner , I know you feel the same.From what I could find, the one I replaced is the Crankshaft Position Sensor. Does it also have a Cam Shaft Position Sensor?
Incidentally , where did you obtain the replacement crank sensor ? Do you still have the previous sensor and was it a factory part ? Was it confirmed to be bad or could a cleaning help ? The factory sensors were the best and MOPAR crank sensors and other sensors are usually the best to replace with since the parts store brands are often questionable .
ENGINE WARM-UP MODE. After Reading the above and knowing what has already been replaced/changed, this really only leaves the temp sensors, Camshaft sensor, or battery causing my issues since it’s only present in the initial start-up and runs fine after everything is up to temperature.
