I am swapping out a 4 cylinder in my '81 CJ5 for a 360. Has anyone one here done such a conversion and if so can you help with the following:
1) will a bell-housing from a 304 work with the 360 and my SR4 transmission?
2) is the clutch kit for a 304 compatible with the 360?
3) can you buy a flywheel for a 360 or is it better to have one from a 304 balanced for the 360?
4) will the starter for the 304 work for the 360?
Thanks in advance for your help.
