So i have went back and forth with a 4x4 issue......thought it was a vacuum leak....installed a posi-lok! Still no 4x4......so i thought i needed to adjust the posi-lok and did just that........while on jack stands the front axle would engage everytime! So i took it for a test drive and it was a little iffy.....it would then it wouldnt? The front axle will engage when i do it on the fly because i can feel it......well sometimes but not even close to all the time! I have a shackle lift could this be the problem? I need some help guys! Thanks!
