Help! jeep issues again....
1995yjguy
Have a 95 YJ with a 4.0 5speed. Slight cam, lifters, 62mm hesco throttle body, cold air intake, Full Banks exhaust. All new plugs wires, etc. Timng is jumping from 10 degrees to 35ish degrees at idle......... Timing chain is brand new. Checked marks and there lined up for correct timing. I have no power and the timing will jump every now and then for no reason and its just not running right. Checked everything else and I was told it is probably the Distributor or internals in the distributor are bad! However I cannot find an aftermarket one for my rig. Any suggestions or HELP would be appreciated.
Didn't DUI make performance distributors for the 4.0 liter's?.
