Hello again
hoobness
Hi. Haven't logged in in several years since I sold my frankenYJ. I have the itch again, that jeep was my favorite vehicle is ever. Since then I've had many unique cars but none give the satisfaction of a jeep cj or yj. I'll be selling a car in a month or so and replacing it with another jeep, probably a cj or yj already somewhat built this time around. My cap is 5500, and I want either FI 4.0, or a V8. I live on the beach in Florida now so a locked, torquey, low idling well cooled jeeep isn't a top priority like the last one. Just a hot rodded, waterproof fun machine is all I want. Have a great day and see you soon!
back and enjoy the forum!
Well, my YJ was a ton of fun while I lived in Miami... I actually bought it there for about $6.5K (back in 2006) with 31's and wheels on it (no other mods), but it was an I4. I also bought a Sahara I6 (also a '94, like mine) for a friend a year later that was $6K (this one had Ox lockers, 33's, mean green starter, tubular bumpers, and a bunch of other stuff, but the hood paint was all shot). So I'm pretty sure you can get an I6 for your budget! Just look around Craigslist and other adds.
Fuel injection does make things alot easier. I use to fuss with my CJ7's carter carb all the time, and it would never idle.
Just me personally, I'd want a factory all stock Jeep that I could do my own thing with. I think most v8 conversions in that price range will be poorly done or unfinished. I think that when people take the time to do a v8 swap right they want a ton of money for it.
I most certainly agree that a swap involving engines and transmissions that were not originally designed will no doubt be very involved just to get them mounted correctly and work right as well . Which will always involve adapters that are costly. Hence the phrase "labor of love".
carburetors will always command our attention . You can do the best rebuild , sealing fuel bowl leaks , float setting , choke setting , etc. , and eventually will have to be done again . Floats get gas logged over time necessitating rebuild , gasoline just has its way of doing its deeds to internal parts , especially the new ethanol gas . Fuel injectors need attention too but no way near what a carburetor does. Some carbs are just troublesome by design. I like carbs because I used to take pride in rebuilding them but F/I has many advantages , especially for off roaders . No more float bowl slosh and bog on hill climbs. As far as V8 swaps , if you really want a V8 , I could understand , but for practicality and simplicity to spend less time tuning and maintaining , it is best to seek more HP/TQ from your existing engine or upgrade to an engine in the same family to keep installation simple and inexpensive. Not even just jeeps , I once had a hand in putting a small block Chevy in an AMC rambler which NOTHING fit and we had to engineer everything.
Adapters are available for so many engine/trans swaps but it all comes down to $$ .
i would definately go with the 4.0 swap as it replaces a 258 and will work out much easier . Just make certain that all your parts match so that it will be a true bolt in and nothing left out such as trying to get a CPS to work with a bell housing that never had one , for example. I think a 4.0 will be all you need and is not an over complicated swap as CJ's and YJ's had I6's so will just come down to wiring for PCM and a new fuel system.
:welcome: [Back] new format somewhat of the forum since you were here last. Enjoy!
Hey Terry, was that an AFB or one of the little 2 barrel Carters? The genuine AFB on 'BB' is stable as granite as is the little Carter YF on 'Easy Bake'
