Hei/nutter bypass mods
J:UN
I'm going to do this mod eventually but wandered if it will effect the emisions? or should I go and do the emmisions test before?
Well...I suppose in terms of the "letter of the law," sure it will affect your emissions legality.
The purpose of the "Nutter Bypass" is to put the emissions control computer to sleep. That sleep-mode disables the ability of the computer to on-the-fly adjust the fuel-air mixture ratio of the Carter BBD and to on-the-fly adjust ignition timing.
Ergo! No reduction of emissions.
Most web articles regarding the Nutter Bypass that I have read include a prominent disclaimer which explicitly states that the modification will cause the Jeep to be emissions illegal.
Configuration enforcement and emissions testing, however, are horses of other colors. From what I have gathered reading posts on the topic, emissions enforcement varies by state and sometimes by region within a state.
Who knows what you might get away with where you live?
Gadget
I have a copy of the nutter bypass instructions in my truck if you want me to fax them to you.
