heated seats
98 Jeep
It seems like everyday a new problem creeps in with this jeep. I posted a question about the sun roof not closing properly. It doesn't leak or anything like that but it's not closed right. I use to hear the motor when I would switch the motor on but now it is dead. It seems like it is raised a little on the drivers side at the rear corner. Another thing is the heated seats, they feel anything but heated. What regulates them a fuse?
Sorry, i just now saw this after you last post. I hope this helps.
The heated seat may be inoperative due to an open circuit in the heating element located in the seat cover. The condition is usually present in the seat bottom. This Technical Service Bulletin provides a Repair Procedure, which eliminates the need to replace the seat bottom cover.
DIAGNOSIS:
Disconnect the 4 way connector under the seat bottom at the rear of the seat. Check continuity between pins A and B with a digital ohm meter on the seat side of the harness (See Figure 1). The Resistance should be between .9 and 1.4 ohms. If the circuit is open, Perform the Repair Procedure. If continuity is present and the resistance value are correct and the heated seat is inoperative, further diagnosis is present. Refer to the appropriate service manual for diagnostics.
PARTS REQUIRED:
QtyPart No.Description205015478AAHeated Seat Repair Kit (2 required per seat)
REPAIR PROCEDURE:
  1. Position the seatback in the half recline position to gain access to the fasteners.
  2. Disconnect the wire harness from the seat assembly.
  3. Remove the seat attaching nuts and remove the seat from the vehicle.
  4. Remove the seat cushion side cover trim.
  5. Remove the recliner to seat cushion bolts and inboard seat back to seat cushion bolt. Remove the seat back. CAUTION: CARE MUST BE USED WHEN REMOVING THE COVER FROM THE SEAT BOTTOM. THE SEAT IS ATTACHED TO THE FOAM CUSHION WITH HOOK AND LOP FASTENERS. THESE CAN BE TORN WHEN THE COVER IS REMOVED. USE CARE TO CAREFULLY REMOVE THE COVER TO AVOID TEARING THE HOOK AND LOOP FASTENER FROM THE FOAM. IF THE FASTENER IS TORN IT MUST BE ATTACHED TO THE FOAM USING A SUITABLE ADHESIVE SUCH AS MOPAR SPRAY ADHESIVE, P/N 04856957 OR EQUIVALENT.
  6. Disengage the seat cover J straps from the frame. Carefully remove the cover from the seat bottom making sure not to damage the hook and loop fastener on the foam cushion.
  7. The system contains two heating elements per seat. Unplug the two wire connectors and check the continuity between the two terminals in each connector to determine which heating element is open (See Figure 1). The resistance should be .9 to 1.4 ohms. An infinite resistance indicates an open circuit. Each repair kit will repair one element. It is recommended that both elements be repaired even if only one is open.
  8. Trace the wires into the foam and carefully slit the foam using a sharp knife, following the wires until the heating element solder joint is located (See Figure 2). This is the location the open circuit is usually found. Cut the harness from the element as close to the solder joint as possible. If the seat cover has a gray lining, it may be necessary to trim some of the fabric around the glue until the element is exposed. Remove all loose debris. It is not necessary to remove the glue from the cover. Do not discard the original harness. Some vehicles will require the use of the original two wire connector later.
  9. There were two types of heating element used in production (See Figure 3). One has insulation on the wire and one does not. If the element has insulation on the wire, carefully strip one inch of the insulation from the element to allow for soldering. Pull the elements away from the cover enough to clear the foam for soldering. Trim the foam as necessary to provide adequate clearance for soldering.
  10. The soldering procedure requires a technician skilled in soldering fine electrical/electronic wiring. Using a soldering iron and rosin core, solder the new harness to the heating element as shown in Figure 4. Do not use any soldering equipment utilizing an open flame for this procedure. This could damage the foam cushion. Make sure utilize the proper soldering procedures and heat the wire hot enough to melt the solder to avoid a cold solder joint. Cut piece of heat shrink tubing in half and install it on the wire as shown. Shrink the tubing using a heat gun.
  11. Peel of the paper backing from the adhesive patch on the new harness and secure the harness to the cover as shown. The elements require at least one inch clearance between each other to eliminate the possibility of them shorting together. Make sure to route the wires as shown and install the cover patch to fully secure the new harness to the cover. Trim the cover patch as necessary to clear the hook and loop fasteners.
  12. The new harness will plug into most of the existing seat harnesses. Some vehicles utilized a red insulator, which is keyed differently than the green insulator provided on the new harness. If the vehicle utilizes the red connector, it will have to be removed from the original harness and installed on the new harness using solder and heat shrink tubing as shown in Figure 5. Be sure to stagger the splices as shown.
  13. Check continuity at both of the two wire connectors to assure good solder joint.
  14. Repeat this process for the second heating element.
  15. Install the seat cover to the seat bottom.
  16. Install the seat back.
  17. Install the seat and connect the harness.
The sun roof may be inoperative or stuck partially opened. This may be due to a cable guide tube which has separated from the guide tube bracket. A repair kit has been released to allow for replacement of the tubes instead of assembly replacement.
DIAGNOSIS:
If the sunroof is inoperative or stuck in one position, inspect the cable guide tube. If the tube has separated from the bracket, perform the Repair Procedure.
PARTS REQUIRED:
QtyPart No.Description105014766AACable tube repair kit.
REPAIR PROCEDURE:
This bulletin involves replacing the sun roof cable tubes.
CAUTION: THE HEAD LINER IS A ONE PIECE, MOLDED COMPONENT WITH LIMITED FLEXIBILITY. USE CAUTION NOT TO BEND IT EXCESSIVELY OR DAMAGE MAY RESULT.
  1. Remove the A, B and C pillar trim moldings
  2. Remove the upper liftgate trim molding.
  3. Remove the right side D pillar trim molding and upper portion of the left side molding.
  4. Remove the sound bar if equipped.
  5. Remove the sun visors and disconnect the vanity lamp wiring if equipped.
  6. Remove the assist handles.
  7. Remove the push plugs from the roof support.
  8. Remove the dome/reading lamp or overhead console.
  9. Remove the sun roof welt from the opening.
  10. With aid of an assistant, carefully remove the head liner from the vehicle. Use care not to damage it.
  11. Disconnect the four drain tubes from the corners of the drainage tray.
  12. Remove the overhead console bracket screws and let the bracket rest on the console.
  13. Mark the location of the sun roof relative to the roof with a grease pencil to ease installation and eliminate the need for later adjustment.
  14. Disconnect the wire harness. With the aid of an assistant, remove the sun roof attaching screws and remove the sun roof as an assembly. Place the assembly on a clean protected work bench.
  15. Using a 1/8 inch drill, drill out the rivets from the bracket that holds the drive tubes in place on the motor and remove the bracket. See Figure 1. Clean all shavings out of the area.
  16. Disconnect the drive cables from the motor gear.
  17. Remove the two screws that hold the spring stop and cable guide tube bracket from the under side of the tray. See Figure 2.
  18. Remove the tie straps holding the tube and harness together.
  19. Remove the guide tube by pulling the tube out of the housing and pulling the cable out of the tube.
  20. Slide the new tube over the cable and position it in the assembly.
  21. Install the guide tube bracket and spring stop using the screws removed previously. Tighten the screws to 3 Nm (27 in. Lbs.).
  22. Install the tie straps.
  23. Repeat the procedure for the other cable guide bracket.
  24. Position the sun roof glass in the full open position.
  25. Insert the drive cables into the motor drive gear.
  26. Position the tube bracket over the gear and attach the bracket using the rivets provided in the kit.
  27. Install the sun roof assembly into position. Make the necessary electrical connections and cycle the unit to assure correct operation.
  28. Connect the drain tubes to the tray.
  29. Install the head liner and related components by reversing the removal procedure. Use care not to damage the head liner. Use care not to trap or pinch any wires when installing the sun visor or overhead console/dome lamp.
Thank you so much for the reply but I think I'll hold off till spring for this repair as I don't have the luxury of a heated garage.
Now if I can ask something else that is wrong. The sun roof. The day we brought this vehicle home my son drove it and he just had to open the sun roof which worked fine. I really don't care for them but 1 day about 2 weeks later I tried to open it and all I heard was the motor turning but the roof would not open but when I was waxing this thing 2 weeks ago I noticed on the roof at the rear of the sun-roof on the drivers side it looks as though it is not closed properly. We've had plenty of rain and it isn't leaking but are there any ways I can get this thing closed right, I also can't hear anything from the motor anymore, is there a fuse that runs this?
