Fuse Placements
mrgus'jeep
i have a 1998 wrangler se, and contacted local jeep dealer for an owners manual, they are not available any longer they tell me. where else can i get fuse legend to let me what circuit they are in. i bought a haynes manual and it wasnt very specific
thanks
jeep on
1998 Jeep Wrangler Fuse box:
(5 cavities/slots across and 4 cavities/slots down)
They number them from top to bottom and right to left. The top right hand corner cavity would be cavity #1 and the bottom right corner is cavity #4...
(Last/5th column on panel numbered from top to bottom)
#1 - 20 amp yellow fuse - Park Lights
#2 - 20 amp yellow fuse - Stop Lights
#3 - 20 amp yellow fuse - Fog Lights
#4 - 10 amp red fuse - Door Switch Defeat
(4th column on panel numbered from top to bottom)
#5 - 10 amp red fuse - Airbag
#6 - 20 amp yellow fuse - Rear Wiper
#7 - 10 amp red fuse - Back-Up Lights, Rear Window Defroster, ABS
#8 - 20 amp yellow fuse - HEVAC
(3rd column on panel numbered from top to bottom)
#9 - 10 amp red fuse - Airbag
#10 - 10 amp red fuse - Instrument Cluster
#11 - 10 amp red fuse - Power Distribution Center Coils
#12 - 10 amp red fuse - Panel Lights
(2nd column on panel numbered from top to bottom)
#13 - 10 amp red fuse - Turn Signals
#14 - 20 amp yellow fuse - Front Wiper
#15 - 10 amp red fuse - Radio
#16 - Open - No description
(1st column on panel numbered from top to bottom)
#17 - 10 amp red fuse - HBL Switch
#18 - 15 amp blue fuse - Acc. Battery - Optional
#19 - 20 amp yellow fuse - Acc. Switch
#20 - 20 amp yellow fuse - Clutch Interlock Ignition
