fuel pump removal
Dusty waters
I need to drop my fuel tank, the issue is the filler hose at the tank has no access to clamps. I can get tot the filler spout clamps but then the hose still goes through the frame. I could use some advice on this. Thanks
Any chance you could post a photo of the area you are talking about.
I've never worked on a 1993 Cherokee myself, but my 2005 TJ took quite a bit of work to lower the tank. I had to lower a few inches and disconnect hoses on the way down.
When I replaced the fuel pump on my 1990 Cherokee I didn't need to drop the tank. It was a little awkward and tight but it beat dropping the tank.
