use rtv sealant on the gaskete, can get it at autozone. If the line is leaking at the fittings then use thread tape on it, rip off about a two inch section of the tape and u just wrap some of it around the treads of your fitting and it makes for a tight fit. Try putting some gas in the carb and start it, you may need to do this a couple times before the gas reaches the carb from the tank. they can be tough to start sometimes after a fuel pump change. putting gas in the carb and starting it will suck the gas from the tank to the pump. which is why it may take a few times.
