1059746
Ok, had trouble starting the Jeep this morning. I believe that the fuel system is not maintaining pressure when the Jeep is turned off. The engine would turn and turn but not start. Finally, I barely ignited and with a stomp of the pedal, it rolled over. The fuel works fine when driving, not a single problem there. So after I got here to work, I cut it off and then started it up again. It started on the first try. But maybe that's because it still had some good fumes and left over fuel in the cylinders.
Does this sound like the fuel pump or sending unit? If so, is it possible that it works fine when the motor is running, but not before? I have an 89 YJ. Anyone had this problem before? I believe the pump and sending unit are in the tank, so it would require a drop to replace it, and I just filled the tank last night! Thanks for any help.
:-? :-? [addsig]
:-? :-? [addsig]
