OK, I changed out my fuel pump this weekend because I needed to put a new gasket on it. Had a leak around the gasket that needed to be fixed anyway.
Problem is, now I have a new fuel pump and gasket, but now have a fuel leak at the top of the fitting for the metal fuel line. I have taken it off and put it on several times thinking that the nipple was not sealing properly. It is not a big leak, but a leak none the less. Any ideas of how to fix this? Would plumbers putty be a good fix?
Thanks, Joel
Thanks, Joel
