Hello!
Recently I swapped stock fuel injectors on my 1987 Wagoneer Limited. It fires up right away, doesn't stall or misfire. But it runs RICH. I assi swapped the fuel rail regulator, coolant temperature sensor, all throttle sensors. I've cleaned the cooling and fuel systems the best I can with rust treatments and Lucas products.
Any thoughts on what else I can check?
Sent from my SM-S908U1 using Jeepz.com mobile app
