Jeepenstevo
I have a 1990 yj with a carter carb but the cater isn;t my prob its ideling fine. In the mornings ill get it crank her up and give some gas and 5 to 10 secs later it will just cut off. When i try and crank it again it wont turn over. :evil: I took a look at it a found out that no fuel was getting to the carb. so i pulled the gas line off at the carb. and noticed there was no gas there. Then i decided to prime the line by getting someone to turn the key. Here came the gas just shooting out. I hooked tthe line back to the carb and tried to crank and after about 5 secs of turning the key it started and runs great.
Almost every morning i have to go through this to get my jeep to stay running. Does anyone have any idea what may be causing this? Could it be the fuel pump?
