R rbnhd55 New member Sep 20, 2012 #1 I have a 1998 Wrangler Sarah and need a front differential gasket, the one I got from NAPA does not fit and its the only one they show? Thanks
TerryMason Administrator Staff member Sep 20, 2012 #2 I think you'll be better off using RTV (I believe RTV black is what you want). I don't normally use a gasket on the differentials, but even if you do I'd suggest using RTV on it. Like number 5 here: http://www.jeepz.com/forum/drivetrain/37911-changing-differential-fluid.html
wwch99tj New member Sep 20, 2012 #3 This is the RTV silicone I used Sent from my DROID 2 Global Attachments ForumRunner_20120920_140732.png 643.4 KB · Views: 474
Catoctin Jeep Official Vendor Sep 20, 2012 #4 I have found that the Lube Locker gaskets work great and are reusable..
