1047838
I have a '90 Wrangler 4.2L and the front axle won't engage. The front driveshaft is powered when I shift into 4wd though. Most of the troubleshooting stuff for the front axle shift motor I've read refers to this unit as having 2 vacuum lines, but mine has three (two ports on the edge of the "pancake" and one on the flat side of it). What does each of these lines do? Also, if I am able to determine the problem is actually the transfer case switch, how is the switch attached? On top the transfer case it seems like there is a little tower with four ports in it, and a rubber manifold that plugs into the top of it. Is this the switch, and how is it attached?[addsig]
