1065203
1989 YJ, 4.2L, 5SPD, 2" Body Lift, 188000 miles. Week ago started to notice some strange wobbling when taking off from a dead stop. Jeep goes side to side a bit then fore and aft. Checked the suspension and found that holes in the frame that the rear spring shackle mounts to are rusted out. On the drivers side, there is a 1/2" gap behind that shackle bushing. Not as bad on the passenger side. I'm sure that others have come across this in the past. What type of fix did you do? some have said I need to find a wreck and hack off enough good frame and weld on. Others say that I can box the bad frame with plate steel. I'm either going to fix and keep, fix and sell or sell as-is, but can not decide. I've been to two shops that say no-way will they touch it. Thoughts? :-? [addsig]
