well... for mounting the axle... that is basically all you will need.... then make sure you have the right gears in each axle... some people won't run a wide axle on a jeep.. I prefer the stance myself... looks good, helps you stay on all 4's... just doen'st allow you to get through the spaces... so some people shorten them... depending on brakes... you MAY have to convert some lines, chances are that you'll be ok though... Parking brake may need some tinkering, if you will be running them at all... there's not much to an axle... just basically make it look like the 35
