cewtwo
OK, I got a major air leak in my Ford 8.8 rear axle.
I R&R'd it and found the bushing was wrapping itself pulling the copper air tube tight. When it did, it wore a hole at the very end of the copper tube.
I got a new bushing from ARB and replaced it. I went heavy oin the pre-load and set the backlash to within tolerance. I took out the Mighty YJ and everything ran good.
I noticed the differential cover was hot after a trial run about town. Not burning hot, but warm to the touch.
I am assuming that the differential will need a break in period and that the extra heat will go away after that.
I figured that I better ask before I tore into the axle again.
Any opinions?
Any opinions?
