RE: 89 wagoneer axle specs?
Check the numbers on the metal tag bolted to the diff cover. 1st three digits on the first or second line should be the gear ratio. Should be 3.07, 3.55, 3.73, or 4.10.
You can also pull the diff cover (to service the fluid anyway) and check the numbers stamped in the edge of the ring gear. Divide the large 2-digit number by the small 2-digit number and you'll get your gear ratio.
