All, done! I went with 6X6 (cause it is covering some body damage) with 1.25 dom tubing! I have to admit that I did not under take this all by my-self! I need to give props (Is that what you kids say now-a-days) to Zach over at AtoZ Fabrication for the help!
Before (you can see some of the beating that the rockers have taken, and this is the good side.)
During
Cleaned up and primed and painted the rocker section!
I went with a couple coats of primer, couple coats of flat black, then I used dupli-color's rubberized undercoating on all surfaces (eccpet the part you step on) to help seal, and protect the metal (plus it gives that cool textured look) Then I sprayed three coats of rustoleum's cracked hammered finish! very durable, I used it on teh frame of my hot rod three years ago and still shows no wear!
After with a lot of stainless hardware.
This side had the worse damage out of the two, you can see some of the paint behind the jeep sticker.
Thanks for looking!
During
Thanks for looking!
