Factory Grizzly Rims
ATHiker
I am looking to get 31" tires for my 2000 TJ, I have the factory spoke Grizzly Rims, with stock 225-75R15 on them The tires I am looking at is 31X10.5 15 Does anyone know if they will fit on these factoy rims???????? :?:
Thanks in advance
I am not sure of the width of your stock rims but it is not uncommon to see that size tire on many stock trucks. The advantage is when you are running low tire pressure but it may cause tread to wear uneveanly.
I have 265/75r15 ion my 97 is that a 30 or 31 I dont know but they are hard on my 4 banger.
It figures up to be about a 30.6" so your kinda right in the middle.
As to the running 31x10.50s on factory rims, Ive never heard of anyone having any problems, but you might wait till someone who has those rims posts their experiences.
HTH
Nathan
You should be able to fit 31s on your Grizzly rims. They are 15x7 rims and you can actually fit up to 32s on them.
YES. The grizzlies are 15x7 and you can fit 31's easily. In fact, many jeepers even run a 12.5" wide tire on 7" rims because the bead will hold better than on a wider rim.
C
