Exhaust gasket
robertr11
New guy here
I have changed the exhaust gasket several times this year. It loosens up after about a month and burns out the gasket if not tightened properly. I have a 89 TJ with a Hedman header. Is there a gasket that will stay?
Thanks in advance
Robert Rice
when you replace the gasket use lock tight on the exhast manifold bolts that way they wont come loose and bolts should be retorked in about a week after eng run a few days this should solve your prob
