I've replaced the fuel pressure regulator and crank sensor. I haven't checked the fuel pressure with a gauge yet. But it doesn't seem to have much pressure when I push in the shraider valve. The jeep runs fine once it has started, even under heavy throttle.
This is a list of every thing I've replaced. ( distributor, plugs, wires, coil, fuel pressure reg, crank sensor, and air filter.) I tried to replace the fuel pump, but all the after market pumps I put in failed after a few days, so I put the old one back in.
