mississippi
my electric fan will not cut on. i have changed the relay in the pdc and it still will not cut on i can use a jumper wire on the relay and it will start. any idea on where to look for a short at
Nope, the GC's relay is located under the passenger headlamp and housing. the best way to service the relay is to remove the passenger headlamp then cut a square access hole to reveal the relay. There are 2 screws holding the relay to the body. Remove the screws then carefully retrieve the relay and disconnect the electrical connector. dont let the connector go back in the hole until you plug in the new relay. Before you install the new relay, apply a small amount of dielectric grease on the bottom of the relay. Most often the relay is all needed to fix the inop radiator fan but sometimes the fan module is also inop.Heres a diagram for your GC.Ok so i have a 03 grand cherokee inline 6. i have a simular problem. i went on a trip about 2 1/2 hrs and i get off the interstate and once i do the temp gauge goes to about 230. i quick made it to a parking garage and parked it. when i was ready to leave i made it about 60 miles before i got to my parents house. I figured it was the fan motor. It wasnt. the fuse is good and when i turn the AC on i can hear a click like the fan trying to turn on but it doesnt. i am thinking relay and i am looking for more advice.
Is my wiring diagram the same as the one above?
so there is a fuse inside the truck? is that right? Otherwise i am leaning towards the relay. does that sound about right to you? i have replaced the fan motor and the fuse under the hood was good but i didnt know there was a fuse in the truck.
