Easiest way?, remove everything in the front of the timing cover and remove the timing cover . Installing it will be a different story.. I found that it's easier to remove the oil pan so that the dowels on the block to the timing cover would line up a lot easier. This would be an opportunity to re seal a leaking oil pan gasket and or a leaking rear and front main seal.
