Bounty__Hunter
Super Moderator
The XJ/TJ front driveshaft won't bolt up then, as the double cardan joint does not leave uncovered ujoint cups to be bolted to the AA yoke with the ubolts. The ujoint cups are mounted into the end of the double cardan joint.Snitty said:AA yoke... mounted to the output by a nut... the ujoint mounts to the yoke with ubolts... not included... but easy to come by
Take a look under the front of a TJ or XJ, you'll see what I mean.
