Driveshaft Joint Problems
javcamac
Hi guys,
I recently change the front & rear driveshaft joints and new straps & bolts. Now I feel some vibrating while running. In fact, I not remember if I returned to its original position. I will change it tomorrow but if there something else that maybe help please let me know.
Thanks, jc
Make sure none of the balance weights got knocked off.
Double check your work. Make sure that all the u joint caps are setting where there suposed to. It's easy to lose a needle bearing and not have a cap sit where its suposed to. Put the vehicle on blocks and run it in gear and watch the driveshaft to see if there's any wobble there. May be one of the new u joints is not perfect. Remember where most of the aftermarket stuf is made.
After all...the problem was that the sliding yoke of the rear drive-shaft was not align within the shaft. I remove the sliding yoke and install again in alignment with the shaft and both yoke. Now the CJ run smoothly...
Thanks...
