dolly towing
bowen
i just bought a new wrangler and from what i am reading in the owners manual i cant tow it behind my rv on a dolly does anyone know anything about this????
Jk?
The Jeep® brand was recognized as the Best Dinghy Vehicle by the Good Sam Club for 2008. Wrangler's are ideal for towing behind RVs because their two-speed transfer case has a Neutral that minimizes wear and tear to the drive system. Read more about it from the Link . http://www.jeep.com/en/2009/wrangler/capability/towing/
You can flat-tow but the owner's manuals tell you not to tow with either end off the ground and the other on the ground.
To get around this, simply disconnect the driveshaft from the pinion flange of the axle that is on the ground, and tie it up.
I've both flat-towed and dolly towed quite a bit with no problems.
