Does this look right?!!!!!!!!!!!!!!!!
josue estrada
trying to get the welding going. This is the pitch. Does it look fine? it spins alright.
I am in the garage so if you could text me at 708 271 0765 and let me know asap I would appreciate it !
It's very wrong. For your single cardan setup you want the pinion angle parallel with the transfer case output.
Your setup is ideal for a CV (double-cardan) rear driveshaft, which yours is not.
This is what you're shooting for:
Is all the weight on your rear suspension? I don't think you'll be able to get the rear pinion down to where it should be without the front ujoint binding. Your best answer is either a SYE install with CV rear driveshaft, or lower the transmission crossmember.
