Airborne105
We posted this problem before at the end i will go over what I have done with none of it fixing the problem. I have a 2.5L, '95. It will start up just fine but then die without any warning signs. No spitting or sputtering...it just dies. I've looked under the hood and can't see anything obviously wrong. It ranges from hard wheeling for three hours to 17 seconds of run time. I only have to wait for about a minute or less for it to fire right back up again. So far I have replaced the fuel pump, fuel filter, the alternator(6 months ago), and he's got a low temp thermostat in(160) I have now replaced the idle air control valve, TPS and crank shaft position sensor. After I replaced the TPS it ran great for a day and took it out in the mudd for about 4 hours. No problems what so ever. Pulled into the driveway and it started all over again. Bumps dont cause it to die, ruling out a loose wire. Doesn't matter if it's wet or dry. Also I havent been able to recreate a scenario that makes it die , just seems to do it when it wants to. Any help would be great before I put a bullet in it
