Are there any YJ owners out there that have the JKS trac bar quick disconnect?? I see that is sells for $199.00 which not all that bad of a price, free would be better, but someone has to pay Mister JKS his dues!
If anyone has one or knows someone, how is it's performance?
It appears that it is nothing more than a small bolt that goes through the slip shaft and holds the spline in place. My YJ is not a daily driver but it does see a lot of use on the weekends, does this method of securing ever loosen up?
Is the articulation really that much more??
I had a home made trac bar disconnect that I came up with and with the bar off, my front tires were being stuffed into the fenders, accually ripped the bumpstops off. the issue with my set up is that is was not a real tight connection. I used a clevis pin, some washers and zip ties ( to hold the trac bar up when not needed) and thats it. I would also get a lot of front end rattle from the trac bar cause it was a little loose.
I have since replaced my ingenouse set up (Which was not one of my best ideas) with the original trac bar, but I miss having the extra stuff and drop.
can somebody give me some feed back on the JKS trac bar quick disconnect?
