You could also jack both rear wheels off the ground, put trans in the highest gear for a 1.1 drive. mark your driveshaft and have a friend help you turn both rear wheels at the same time one whole turn and count how many times your driveshaft turns. example: 3 1/2 turns would be 3.54, 3 3/4 turns 3.73, a little over 4 turns 4.10 and so fourth. Its not exact but gives you a real close guess.
