I'm wondering if I were to install a set of cut out fender flares if that would give me enough room for 33's...this way I wouldn't have to do a temporary body lift till I can afford my spring over. Right now I have a 2 1/2" spring lift and the revolver shackles give it another 3/4". I fit 31's no problem, 32's will fit but will rub with every little bump I go over. The height of the tires isn't that much of a problem, it's the tightest fitting at the ends (or bottoms) of the flares if you know what I mean. How much more room will cut outs give me both at the top and ends of the flares? I eventually want the cut out's anyway.
