crank pulley
kaw2000
I have a 94 Grand C. 4L. The outer crank pulley has separated from the inner pulley.
Has this happened to anyone else? There is alittle room to work, I was wondering if I can remove and install a new pulley without pulling the radiator. Thanks for any help.
That depends on the type of puller your using. Most vibration damper puller are fairly large and will require the radiator to be removed.
