Yeah, what Tug said. Don't order the shaft until the lift is on and everything is bolted in place. THAT INCLUDES THE NEW BELLY-UP SKIDPLATE whether you buy or fab one. That will change the height of the t-case and thus change the length of the driveshaft. The driveshaft should be the last thing to order because the measurement has to be exact.
C
ps. go for 35's... but only if you get the TJ flares AND a 1" body lift. Do the Daystar.
