Control Arms
phatyaspen
I am looking into getting enw control arms for my TJ... what do i ned to look for?i think ineed lower,upper front and upper rear...is that right? what companies do you recommend? all i have heard about it rubicon express any other good ones?
i only have 4 inchs of lift but plan on 2 in spacer lift and a 2in body lift...someone point me in the rigth direction please :!:
You should be okay with longer adjustible lower control arms front and rear. Anything higher than 4" and you should consider a longarm kit.
Even with a 4 inch lift I would say go to a long arm kit. It smooths out the ride making the exspence worth it. At greater heights it is a must.
As to companies.. Tera-flex, and Rock Krawler are good ones for TJ in my opinion.
Drops .02 cents into the forum bucket and steps off the soap box...
Next!
