Commanche Transmission Fluid
xt master
88 Comanche with 4.0 all stock,not sure which transmission..auto..What transmission fluid should I use?
ATF +4 from a dealer. Semi synthetic and it's fill for life. It takes place of all other Chryslers previous trans fluids.
Thanks for the help.
What did you manual say bugleboy,I dont have a manual for mine.
ATF +4 is amazing. I run it in all my race transmissions.
ATF4 will make an AW4 start shifting weird. Extra cost for no bonus.
There's a club for Comanche owners too
Only if it's toast. If you can't feel an aw4 shift. There's something wrong with it. But that should be true about any trans. If it chirps the tires on a shift it will last forever. If it shifts nice. It won't.
ATF+4 is synthetic blend and twice the price of Mercon/DexronII/III, which is the ONLY fluid spec'd for the AW4 from the manufacturer.
