I am upgrading my coil to get more spark. Question is, can I take the red and green wire out of the coil adapter and just attach them straight to the coil. I am asking because my new coil will not accept the stock ford coil adapter. red wire to positive pole and green to negative pole on new coil, am I correct?
Also, 1st and 2nd gear are difficult to shift into. what are some reasons that may be causing this. Also, I am getting some chattering when shifting into reverse.
Thanks for all of your help.
